Author Topic: witch cam to choose from  (Read 18807 times)
penske2704
Re: witch cam to choose from
« Reply #30 on: July 08, 2010, 06:54:59 AM »
going back to that cam question
this is be the biggest cam available so i wonder what king of problem i am gona go accross installing that  :eek:
and wat is going to be required to run this cam
« Reply #31 on: July 08, 2010, 08:06:01 AM »
125 per piston, about the same as a good piston for a dirt bike...
On the other hand there are some really pretty good ones Like I used for about 250 for 4... Hyperutechtics...
looked to me that the price was per piston not the set of 4
EDIT: looked again and it is for the set, i hope they're forged for that price though
they have Keith Black forged pistons and are a tad cheaper for a set of 6 which would make the set of 4 about $400 but they don't have one :(
« Last Edit: July 08, 2010, 08:37:53 AM by sharpxmen »
« Reply #32 on: July 08, 2010, 09:13:11 AM »
found some more info on the Mopar cams
P4529656
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 240-240-24* Duration, .430" Valve Lift, 108 Centerline
P4529657
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 248-248-32* Duration, .440" Valve Lift, 108* Centerline
P4529658
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 256-256-40* Duration, .450" Valve Lift, 108* Centerline
P4529659
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 260-260-44* Duration, .460" Valve Lift, 108* Centerline
P4529660
Factory Engineered Hydraulic Cam and Tappet Package for Mild Competition Application 268-268-52* Duration, .480* Valve Lift, 108* Centerline
seems that all the Mopar cams were 108 centerline, so JF and Bounty's should be the same and it's a stage II. the 260 and 268 is stage III and seen it referred as xtreme comp somewhere, so i would think that there's no way you'd pass emissions with it but i'll give it a shot, if not i'll have to replace the cam every 2 years
Stage I Engine Package A
* Set timing for Maximum HP
* HP Hydraulic Cam 240" or 248" P4529656-657
* Valve Seal Package P4529661
* Valve Spring - Conical P4529217
* Conical Retainer- P4529217
* Low Restriction Enhaust
* Estimated 10 to 20 hp gain over stock
2.5L Jeep Inline 4 Engine
Stage II Engine Package B
Same as Engine Package A except for the following items:
* HP Hydraulic Cam 256" or 260" P4529658-659
* Centerline Cam with Bushing Kit P3690936
* Backcut Valves P4529212-213
* Richen Carb
* Engine oil Cooler P45292690
* Headers
* Estimate 20 to 30 hp gain over Stage I
Stage III Engine Package C
Same as Engine Package A and B except for the following items:
* Increase C.R.
* HP Hydraulic Cam 268" P4529660
* Ported Head P4529644
* Intake Manifold Attaching Package P4529679
* Good Gas
* HD Rod Bolt and Nut Package P4529817
* Estimated 20 to 30 hp gain over Stage II
so if you do all that could potentially be at about 180HP on a 4 banger  :yikes: (cost prohibitive but according to this is possible)
I have also seen that is possible to increase the Intake size from 1.9'' to 2'' and have the intake/exhaust ported and polished
larger t/b and CAI is a given
« Reply #33 on: July 08, 2010, 09:31:35 AM »
P4529656
P4529657
P4529658
P4529659
P4529660
* Richen Carb
* Headers
* Increase C.R.
* Good Gas
his is a different cam; he has 268 duration and .480 lift and I have 256 duration  and .450 lift, so his cam seems to be even more aggressive than mine, and mine was suppossed to be most aggressive street version (read: emmission passing version) of the Mopar Performance Cams...  At least that is what they guy I bought it from said (but it seems right).
penske2704
« Reply #34 on: July 08, 2010, 10:55:49 AM »
there is no emision test here in canada so no problem for that
i just wonder de drivability of this cam  :puzzled:
and like i said if it is too mutch i iam gona find a other one and  put this one 4 sale
« Reply #35 on: July 08, 2010, 12:55:41 PM »
Best way is to try it and see...
« Reply #36 on: July 08, 2010, 01:07:30 PM »
yep, it's a stage III cam, i ordered one too  :naughty:
well, here in Canada there's air-care (BC) - i doubt it will pass with that cam but at least i only have to do it every 2 years so if it fails i'll have to throw the stock one in
for $50 i can play with it, i don't mind, it's really something that you will not find in the future since they're all discontinued
penske2704
« Reply #37 on: July 08, 2010, 10:18:17 PM »
 :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
this cam is gona meet whit a 0.060 bore block and a rebuit head whit a pace setter headers and a 4.0 tb i thik its a good setup ... will see
« Reply #38 on: July 08, 2010, 11:37:25 PM »
The factory valve guides are too tall to handle the talles cams, so its
in cards to have the head done when you do the cam so the head can
be machined for the better springs... and to avoid the valves bottoming out...
My Head had to be relieved and the guides shortened by .090 as I recall....
melbill
« Reply #39 on: July 09, 2010, 09:10:03 AM »
I was looking at the Mancini Racing page that came up from the original link. I can't find the cam there. Am I at the wrong site or just blind. Any help would be appreciated.
Thanks
Bill
« Reply #40 on: July 09, 2010, 09:23:07 AM »
Thanks
Bill
nope, it's gone - just looked
EDIT: sold out, i hope i will still get the one i ordered  :confused:
« Last Edit: July 09, 2010, 09:29:28 AM by sharpxmen »
penske2704
« Reply #41 on: July 09, 2010, 10:30:35 AM »
yha looks like there is no more but i also hope a get the one i ordered...  or helse ... :guns: :guns:
« Reply #42 on: July 09, 2010, 10:57:08 AM »
I should have jumped on the 'cheap' wagon, never know for future builds.
penske2704
« Reply #43 on: July 09, 2010, 11:21:37 AM »
i call them they gono ship monday morning
because it looks like they have a big event there and 90 % of the people working there are gone to the race
so nobody to ship our camshaft
the girl told me that if you  get a confirmation email whit a order number it is sure you have it
and it is genuin mopar part not replica she thold me so i iam wating for a dusty pacage :naughty:
« Reply #44 on: July 09, 2010, 03:10:09 PM »
Makes you wonder where others are hiding, collecting dust...
