Author Topic: Getting the most outa the 4banger?  (Read 5926 times)
wranglerunner22
« on: August 04, 2010, 08:35:13 PM »
Hey all  I havn't posted here in a while.
Im curious to know if anyone has done any of the Mopar cam upgrades or what other cam upgrades are there?
Also I saw the Jet chip module, is it worth it at all for the 200 sum bucks it is? Or what would be a good combo?
Right now Im running completely stock.  I did have the air intake with a cone filter but I was getting shitty mpg for little to no change in performance.  Now I have the stock intake on and am getting 19-22 mpg depending on how/where I drive.
2000 Jeep Wrangler 2.5l I4
vander1020
Re: Getting the most outa the 4banger?
« Reply #1 on: August 07, 2010, 07:19:29 AM »
"Now I have the stock intake on and am getting 19-22 mpg depending on how/where I drive."
I don't get 19-22 mpg if I'm being towed.
« Reply #2 on: August 07, 2010, 05:48:32 PM »
19-22???!!!! another one getting above 20mpg! how the hell are you people doing it???
« Reply #3 on: August 07, 2010, 07:20:37 PM »
maybe there using imperial gallons
« Reply #4 on: August 07, 2010, 08:01:33 PM »
A stock Jeep should get 18-21.  Depending on how you drive, you can eek out a bit more.
elpablodiablo23
« Reply #5 on: August 07, 2010, 08:17:48 PM »
Anything above 18 would be awesome!
« Last Edit: August 07, 2010, 08:22:09 PM by elpablodiablo23 »
« Reply #6 on: August 07, 2010, 08:44:33 PM »
+1 even running 31's highway i got that when I was stock.
I'm running bigger intake and a exhaust header now 4.88's and 33x12.5lt15's
and I don't drive far enough most times highway to figure it out anymore.
I run mainly out in the bush or to work and back witch isn't far from home.
« Reply #7 on: August 07, 2010, 10:54:14 PM »
If you don't drive above 55mph getting 18 shouldn't be a problem.  When the speed limit was 55 MPH, I was able to get well into the 20's with 32's.
With the speed limit at 65 MPH, and with 35's, I have a hard time getting over 18.  I averaged 18 when I was commuting 40 miles.  Now that I'm mainly driving just a few miles (7-14), I'm getting around 15-17.
« Last Edit: August 07, 2010, 10:57:19 PM by Jeffy »
  • Poseur Extraordinaire®
« Reply #8 on: August 09, 2010, 09:13:28 AM »
I got 23?? on my first long trip after picking up the Jeep...bone stock from VA to MI...January 2007?
« Reply #9 on: August 09, 2010, 10:48:03 AM »
but I the question of the thread was getting more out of the 4bangner no? do you mean more mpg's or power?
power the big tb helps some but is mainly throttle response and top end
gears help a lot.
cams and such I haven't tried personal but if you can get one I'm told it helps but you need to do the hole valve train as well to see big gains
supper chips and stuff not sure how much they actually help. in my yj there not really available so I haven't gone that route.
but most of the upgrades will cost you fuel econ if you like to use the power
« Last Edit: August 09, 2010, 10:55:38 AM by Torch_Ind »
« Reply #10 on: August 09, 2010, 12:21:50 PM »
gears help a lot.
Honestly, this thread is a bit too generic and nost of which have other threads going.  With that said, if I had the mods I do now on a stock Jeep, I'd be cruising.
« Reply #11 on: August 09, 2010, 12:31:41 PM »
I'm thinking about doing an overhaul on mine; I think all the mods I have HAVE helped get more out of the Jeep, but my little 4 banger should give me A LOT more if it where up to par...
« Reply #12 on: August 09, 2010, 05:00:28 PM »
what do you mean by that? if you had your mods on a newer jeep it would work better?
« Reply #13 on: August 09, 2010, 06:58:52 PM »
i think he meant with the power mods he has today if his Jeep had no lift and stock tires...
« Reply #14 on: August 09, 2010, 07:27:19 PM »
Exactly.  If I was on maybe 2.5" lift, 31's and a lot less ballast,  I think my Jeep would be pretty quick.
