Author Topic: Best Aftermarket muffler for 2.5 liter?  (Read 4005 times)
RT
« on: August 11, 2010, 11:56:15 PM »
Hey I was looking for a good aftermarket muffler for the 2.5. I was just looking for the performance boost and don't care about the sound as long as it isn't deafening. I was thinking a flow50 or even one of the high end cherry bombs....i'm on a BUDGET :fitz: :fitz: :fitz:   Any advice?
Re: Best Aftermarket muffler for 2.5 liter?
« Reply #1 on: August 12, 2010, 01:12:53 PM »
I would go with a Magnaflow for $50 or a Borla for $114.  FlowMasters suck for a 4cylinder.  A Cherry bomb even worse then a Flowmaster...  If you like noise then get a Flowmaster or better yet a Cherry Bomb.  With both of these you'll probably see a drop on Torque but you'll probably gain a little HP on the high RPM (over 3600).  I've had a Flowmaster break off because of quality issues.  At what they charge, there is no reason they shouldn't use stainless steel like every other band.  Mine broke at a weld and proceeded to fall off while in traffic.  Ended up cutting it all and replacing the whole setup with a cat-back.
If you don't weld the muffler on you could probably piece meal a complete cat-back.
Offline BlueFlu
« Reply #2 on: August 12, 2010, 03:30:32 PM »
The new Cherry Bomb Welded (Flowmaster clonish) sounds good. I've been running one since last fall.
Magnaflow would be a good choice also.
'94 YJ 2.5  4.5" RE lift 33" MTs D30/8.8 Warn 8274......
'96 XJ  4.0  '12 JKU
'02 Ram quad cab, family and Jeep hauler.
97 TJ - I dont wave
« Reply #3 on: August 12, 2010, 09:43:56 PM »
I replaced my rusted through blown out 1 year old Borla muffler after they crawfished me on the warranty, with a MagnaFlow several years ago. Very happy with the MagnaFlow, I have the Magna flow cat as well which creates only 1 pound of back pressure.
RT
« Reply #4 on: August 12, 2010, 11:18:09 PM »
so what model magnaflow?
RT
« Reply #5 on: August 13, 2010, 12:02:57 PM »
i just talked to the muffler guy, he said that a magnaflow would work  best and i shouldn't worry bout losing all my torque because i'm running a stock cat.....bs or no?
97 TJ - I dont wave
« Reply #6 on: August 14, 2010, 09:58:29 PM »
RT... You are splitting hairs when you mention four cylinder and torque in the same sentence. Buy the Magnaflow and the money you save you can invest in a good Chia Pet.
« Reply #7 on: August 15, 2010, 06:55:50 PM »
I'm running cherry bomb vortex muffler and LOVE it!!..
RT
« Reply #8 on: August 15, 2010, 09:32:53 PM »
does it fit the stock pipes?
RT
« Reply #9 on: August 15, 2010, 09:35:52 PM »
....ok that's good, my old one just died  :'( :'( :'(
« Reply #10 on: August 16, 2010, 04:18:16 PM »
I'm running a 2.5inch one but you can get them what ever pipe size you want.
http://www.cherrybomb.com/products/vortex
« Reply #11 on: August 16, 2010, 04:38:31 PM »
how loud is it?
« Reply #12 on: August 16, 2010, 05:12:34 PM »
how loud is it?
mine is a bit louder but I have 2.5inch full exhaust no cat and header and 62mm tb and ported intake.  when I step on it it will breath!!!  If I can get a camara I will record it ok.
RT
« Reply #13 on: August 16, 2010, 08:29:28 PM »
thanks a million, it's kind of a crap shoot finding exhaust for a 2.5 liter...and i really appreciate the help :beers:
Offline Eucalypta
« Reply #14 on: August 20, 2010, 05:31:26 AM »
Here in the Netherlands, we have a dealer who helps you choose the right one.
He just installs one, let you hear it, then installs the next until you tell him it's ok.
Got a stainless steel cherry bomb under my 2.5.
When idling or at "normal" pace; it is pretty quiet.
When pushing the throttle there is a deep dark rumble.
I like the sound alot.
Costs about €80,=
1994 YJ 2.5L - 1996 ZJ 5.2 V8
