Author Topic: Trannie leak  (Read 4880 times)
Re: Trannie leak
« Reply #15 on: August 19, 2010, 08:11:24 PM »
You can do it, and don't worry about the questions, no question is too dumb.  Place a screwdriver or small prybar behind the flat bar section of linkage and work it off the transfer case.  Once the nut is off, it's only a slip fit onto the shaft.
tracker975
Re: Trannie leak
« Reply #16 on: August 19, 2010, 08:17:56 PM »
OK....gotcha...Thanks again Joey
Re: Trannie leak
« Reply #17 on: August 19, 2010, 08:41:07 PM »
Just consider a better topic name...  Trannie isn't what you might think it means.  :whistle:
tracker975
Re: Trannie leak
« Reply #18 on: August 19, 2010, 08:50:48 PM »
LOL..your right....but at least I was close...it is leaking trannie fluid....
tracker975
Re: Trannie leak
« Reply #19 on: August 21, 2010, 12:06:08 PM »
Well...I got the old seal out and the new one in....I just hope I didn't booger the new seal putting the T/C case back in :yikes:....on my back...by myself...with a seperated shoulder and a broken finger lol....had to do a bit of wiggling..not much but it took a few wiggles to get it lined up..then it just slid right in...the old seal was hard as a brick and fell apart when I took it out lol.....I'll let ya know later..........Thanks Joey
Re: Trannie leak
« Reply #20 on: August 21, 2010, 06:49:53 PM »
jeffy meant it's tranny and not trannie
tracker975
Re: Trannie leak
« Reply #21 on: August 21, 2010, 07:27:56 PM »
LOLOLOLOLOLOLOL.........holy crap  :yikes:I can't stop laughing...I just got it....I will be more careful in the future..crap thats funny...Joey
Re: Trannie leak
« Reply #22 on: August 21, 2010, 07:42:22 PM »
Personally, I'd rather call it a Trans or Transmission...
tracker975
Re: Trannie leak
« Reply #23 on: August 21, 2010, 08:08:17 PM »
Make no mistake about it I will definitely change my nomenclature lol....Trans it is...Joey
Re: Trannie leak
« Reply #24 on: August 21, 2010, 09:46:31 PM »
Yeah, 'Trannie leak' sounds pretty bad...
Re: Trannie leak
« Reply #25 on: August 21, 2010, 10:14:06 PM »
probably increased the hits on the website :lol:
