Author Topic: upgrade tranfercase  (Read 1794 times)
rocktime
upgrade tranfercase
« on: August 25, 2010, 10:30:27 AM »
i have the 97 wrangler with the ax5 and my np231 transfercase is not sounding to good making alot of new sounds. i was wondering if anyone has taken the tranfercase out of the rubicon the nvg241or and put it behind there ax5. any help would be great.
Re: upgrade tranfercase
« Reply #1 on: August 25, 2010, 10:37:13 AM »
The AX5 has a 21 spline output. The NVG241 has a 23 spline input. I don't know if anyone makes a spud shaft and adapter to mate the two.
You could do a AX15 conversion then add the 241.
« Reply #2 on: August 25, 2010, 10:58:42 AM »
I would imaging the 21spl input shaft from the 231 would fit inside the 241or, then they'd bolt up.
I'm not a fan of 4:1 low transfer for wheelin here in the Midwest, but I guess it's all in how you set up the rest of your drivetrain and what you're going to do with it.
Wheezer
« Reply #3 on: August 25, 2010, 12:30:35 PM »
Check out JB Conversions' beefed up NP231J case: 6 pinion planetary, fat chain, and ultra short shaft slip yoke eliminator.  Just a thought.
Wheezer
« Reply #4 on: August 25, 2010, 12:57:42 PM »
I haven't heard of anyone doing this but it would be cool if it worked.  Maybe send an email off to Novak (http://www.novak-adapt.com/) and see if they have any insight.
