Author Topic: Broken output shaft. DAMN!  (Read 7767 times)
Re: Broken output shaft. DAMN!
« Reply #15 on: October 13, 2010, 04:08:16 PM »
When you get the new shaft you'll have to rotate your pinion up so it's more inline minus 2-3*.
N8whitie
« Reply #16 on: October 13, 2010, 06:17:48 PM »
Thats what Josh at Tom Woods said too so I'll get that done. I took some pics to show you guys what I see here. Now to me it looks like the cone on the tranfercase where the shaft goes in is about 3 inches or so to the left of where the pinion comes out of the differential. Is it possible the Tcase shifted over?
In this pic you can really see where it looks off.
I put two screwdrivers on the deck.. one is directly under the rear cone of the Tcase where the shaft goes in and the other is directly under where it comes out of the dif.
  I looked at the front drive shaft coming back and it looked plenty straight to me.
« Reply #17 on: October 13, 2010, 06:30:37 PM »
Something has shifted, that driveshaft should be pretty straight if the rear axle is original.
What makes you think the tailshaft broke?  BTW, the tailshaft is part of the mainshaft all the way through the transfer case, it's all one piece.
N8whitie
« Reply #18 on: October 13, 2010, 07:05:49 PM »
Do you think the Tcase shifted? Have you ever heard of that happening?
 I figured it broke because of the noise it made. Definitely sounded like a snap. If that isn't the problem its ok because I needed an SYE anyways but I you may be right. I guess I'm not 100% sure that its broken. My new Shaft and SYE gets here on Monday so I'll see then. Also, I'm taking my Tcase spacers off.
« Reply #19 on: October 13, 2010, 07:13:21 PM »
Check to see if the t-case has it's mounting hardware still and if it's loose or not. Also check the motor mounts. Looks like the drivetrain has shifted.
N8whitie
« Reply #20 on: October 13, 2010, 07:26:01 PM »
Thanks man. I'll check the motor mounts and the Tcase mounting hardware tomorrow. I had it towed to my moms because she has a garage and I don't so when I go there'll look.
 I wonder if something came loose when I took the body lift off? I seriously have no idea what would have caused it.
lanulos89
« Reply #21 on: October 13, 2010, 07:36:29 PM »
was there tcase shift lengthening hardware that you didnt remove, it couldve just popped into neutral. i had that happen to me in my tj i was do 70 down the highway and on the tj the linkage mounts to the body, its the stupidest design ever but a rubber boot tore and it popped into neutral. just food for thought.  you could jack up the rear of the jeep and try spining the rear d shaft if the shaft is broke it would feel funky spinning.
« Reply #22 on: October 13, 2010, 08:46:42 PM »
that is way off, should be centered, like they ^ said something to do with the mount - my guess is the bolts came out (the ones that go in the transmission).
« Reply #23 on: October 13, 2010, 09:28:43 PM »
Looks like the tranny mount broke.
Your pinion is already pointed WAY up, too far up for a standard driveshaft but it should be really close to correct once the SYE is installed.
N8whitie
« Reply #24 on: October 13, 2010, 09:48:02 PM »
I talked to Josh at Tom Woods today about that pinion angle and he said that it would be good once I take the Tcase drop off and the SYE is in as well. The shims are aluminum and you guys had mentioned previously that they can crack so I will eventually take them off and reweld the perches when I find a good price on a welder. You also asked a question on how I know if the shaft is in fact broken and forgot to include that when I grab it and try to move it, it has some play where it goes into the Tcase, like its loose or something. Is that normal?  I have this Friday off so I'm going to go through the under carriage and check all of the mounting hardware as well as the motor mounts.
 It seems like between this jeep undergoing upgrades, breaking and talking with you guys I'm going to be a master jeep mechanic alot quicker than I thought. Ha! I appreciate all of the help and advice from you guys. As soon as this jeep is dialed enough I would love to go hit a trail and I'll spring for a few adult beverages afterwards.
« Reply #25 on: October 13, 2010, 11:07:21 PM »
The noise you heard was probably the transfer case flopping around.  It definately looks like it shifted and the driveshaft and tail cone look OK.  Your transmission mount must be broken for it to shift that much.  Unless it wasn't even bolted down.
You can buy a complete mount set with motor mounts for $35.
N8whitie
« Reply #26 on: October 13, 2010, 11:28:06 PM »
OK cool. Looks like I'm getting a new DS and SYE anyways so that will be going in along with the new mount set up.
Question, How do or what would cause the mounts to break? I was just driving on a surfaced road, not a trail. Maybe just wear and tear over the years?
« Reply #27 on: October 13, 2010, 11:37:26 PM »
unless you're missing the anti-torque bolt i don't think the mount is broken, if it was that bolt would still keep the transmission lined up (the bracket that the bolt goes thru is held in by the 2 mount bolts to the transmission). take some pics, i still think the bolts came lose or got stripped out of the mounting holes  to have the t-case shift that much. I'm really curious to see what actually happened - if you take a pic above the trans skid you should be able to see what happened ( peak or pic - you pick :lol: )
« Reply #28 on: October 13, 2010, 11:39:37 PM »
They could go out a few different ways.  The bolts fatigued and they sheared off.  If the bolts get loose the rocking could shear the bolts.  OR the rubber rotted away...  Look into the skidplate where the transmission mounts to the skid.  You should have three bolts.Two are for the mount and one which helps reduce any torquing from the drivetrain.
« Last Edit: October 13, 2010, 11:40:26 PM by Jeffy »
N8whitie
« Reply #29 on: October 13, 2010, 11:57:58 PM »
OK, I'll go to my moms and get some pics tomorrow after work. I wish I had a garage, I would go take them right now. I'm thinking that there can't be too many different things that would make the Tcase shift that much so that one seems like it makes the most sense.
 Remember when I asked about the wobbling going on on the drivetrain ( shifters, clutch and gas pedal and steering wheel) That had to have been it. They were probably loose and on their way out and that or something over my head just pit the mail in the coffin. Better here than on a trail in the middle of nowhere though... or going 65+ on the highway. Wow, That would have been a nightmare eh?!
