Author Topic: Broken output shaft. DAMN!  (Read 7786 times)
N8whitie
Re: Broken output shaft. DAMN!
« Reply #30 on: October 15, 2010, 04:46:47 PM »
Got it, Thanks for the help guys. The drivers side motor mount is smoked.
tjsean0308
« Reply #31 on: October 15, 2010, 05:04:42 PM »
Well that will do it!!!  glad you found the cause. Might be time for a MML that will help with DL angles maybe could reduce the wedge a bit in the rear too help ensure the pinion bearing stays lubed up and happy.
« Reply #32 on: October 15, 2010, 05:08:05 PM »
« Reply #33 on: October 15, 2010, 05:08:48 PM »
He has a SYE with a CV driveshaft coming.
N8whitie
« Reply #34 on: October 15, 2010, 05:19:59 PM »
The mounts are on the way. I'm taking my fiance to Carmel on the weekend of the 22nd for her bday so I'm going to have to wrench this week after work and hopefully get it all done by then. Its surreal to think that I'm actually going to have a Jepp thats worth a sh!t on a trail now. We have to hit the junk yards pretty soon Jeffy and look for an 8.8 or D44.
tjsean0308
« Reply #35 on: October 15, 2010, 05:23:57 PM »
no such thing as too much oil on a pinion bearing. that was my main point, of course his DL angle will be good with the new DS
« Reply #36 on: October 15, 2010, 05:30:54 PM »
Well let me know, I'll go with you.
« Reply #37 on: October 15, 2010, 06:16:47 PM »
i still don't understand how that can cause the t-case end to shift 3 or 4 inches to the passenger side
N8whitie
« Reply #38 on: October 15, 2010, 06:25:34 PM »
I figured with that mount busted the motor was jumping around for a while working the tranny mounts out of place whih in turn would move the tcase as well.
« Reply #39 on: October 15, 2010, 06:31:53 PM »
ok, i understand that being the cause of the transmision mount failing but that rubber being broken will not cause your t-case to be that far off to the right, did you check the transmission mount?
« Reply #40 on: October 15, 2010, 08:46:59 PM »
Devils 3 way?  :naughty:
N8whitie
« Reply #41 on: October 15, 2010, 09:20:16 PM »
Lets do it. I'm good for the weekend of the 29th if thats good for you guys.
