Author Topic: Broken output shaft. DAMN!  (Read 5900 times)
N8whitie
« on: October 12, 2010, 10:17:03 PM »
So I'm driving home today going through Hayward, make a left turn down Campus Dr and SNAP! WAP! WAP! WAP! I stopped immediately and got out, crawled under my rig to see a broken output shaft. I had to get it towed home.  I guess tomorrow I'm going to get an SYE like I should have done in the first place. I love it, as soon as I fix one thing another breaks immediately after.
Re: Broken output shaft. DAMN!
« Reply #1 on: October 12, 2010, 10:33:55 PM »
Did it take out the rear tail cone?  If not you can get a new output shaft for a quick fix.  $12.  A SYE is a good idea though.  Still, I haven't run one...
« Reply #2 on: October 12, 2010, 11:22:07 PM »
N8, you got the 4.5'' lift if i'm not mistaking, did you get a t-case lowering kit with it? if not that's why it broke, the slip yoke won't slip at that angle, more pull on the output shaft - so you'll either need the SYE or a t-case lowering kit.
« Reply #3 on: October 13, 2010, 12:02:51 AM »
You can see some spacers in one of his pics.
N8whitie
« Reply #4 on: October 13, 2010, 09:18:17 AM »
The cone is fine, i caught the breakage the second it happened so I stopped to prevent anymore damage. I think I'm goint to pick up an SYE today and throw it in. The jeep had the T case lowering kit from the previous guys lift.
« Reply #5 on: October 13, 2010, 09:43:41 AM »
What actually broke?  Was it the drive shaft or something internal to the transfer case?
Either way, an SYE along with a CV driveshaft is good to have.
« Reply #6 on: October 13, 2010, 09:47:06 AM »
didn't notice, SYE then and call it done.
  • Poseur Extraordinaire®
« Reply #7 on: October 13, 2010, 10:43:00 AM »
Why not just remove the shaft and drive home in front wheel drive??
My driveshaft ujoint was ready to fail and I drove around like that for a couple of days.
« Reply #8 on: October 13, 2010, 10:54:40 AM »
with YJs the d/s slip yoke is the one that seals the t-case from losing the fluid, would spill out if the d/s is removed.
« Reply #9 on: October 13, 2010, 10:56:09 AM »
That's a VERY good reason.... :wave:
« Reply #10 on: October 13, 2010, 02:04:28 PM »
From what I have heard a Gatoraid cap is a good fit to stop the fluid from leaking out of a 231 with the driveshaft removed. A bit of duct tape to hold it in place.
N8whitie
« Reply #11 on: October 13, 2010, 02:06:21 PM »
Its strange that I didn't have problems with the previous lift then as soon as I change it I get problems. I did notice that the shims were a bit smaller than the shims on the stock springs. I also notice another thing and its that the skinny part of the shim was pointing forwards on the previous and the BDS kit told me to put the fat part pointing forward.
« Reply #12 on: October 13, 2010, 02:30:56 PM »
There shouldn't have been shims on there at all but with those shackles the PO had to dial back the pinion angle so it wasn't pointing straight up.  The new shims were needed to point the pinion up a bit to get rid of some of the angle.
It breaking when it did, doesn't mean it was the lifts fault.  It could have happened prior but changing it caused it to break.
N8whitie
« Reply #13 on: October 13, 2010, 03:02:06 PM »
Yeah, that thought was in the bak of my head but just wasn't sure. OK, I'm looking at ordering the Heavy Duty SYE kit for the NP231 from Advanced Adapters. Am I going to need a new ear rdriveshaft as well? Im reading the page here and thats what it sounds like.
N8whitie
« Reply #14 on: October 13, 2010, 03:45:34 PM »
Just called Tom Woods and my SYE and rear double cardan DS is on the way. Whole thing cost me 530 in total but I figure i might as well go with top quality if I'm replacing things now.
