Author Topic: ax15  (Read 5670 times)
N8whitie
ax15
« on: October 25, 2010, 04:58:19 PM »
Just saw an AX15 on Craigslist for 250. What would I have to do to fit it in my 95 YJ 2.5? Is it even worth it?
Re: ax15
« Reply #1 on: October 25, 2010, 05:53:24 PM »
You would need a Dodge Dakoda 2.5L Bell housing.
Re: ax15
« Reply #2 on: October 25, 2010, 07:27:10 PM »
really that can get the ax-15 in. shit wish I would have know that
Re: ax15
« Reply #3 on: October 25, 2010, 09:29:00 PM »
that + t-case input shaft and a camaro 4 cyl clutch disk. You also need a longer clutch slave pushrod.
sbsg2005
Re: ax15
« Reply #4 on: October 26, 2010, 11:30:14 PM »
Make sure the bell you get is fro a 96 or newer 2.5 equiped dakota cause the 95 and older 2.5s are actualy a chrysler common block, while our 2.5s are amc. they are two totaly differnt blocks. Make sure the ax-15 is already set up for a external slave if not you will have to buy a new input shaft bearing retainer. On my 95 i didnt need a longer push rod but yours may be different. I did have to get a adapter pilot from advance adapters but it was less than 20 bucks. and i had to lengthen my fron drive shaft since the swap moved the transfercase back 2 inchs. the 4.0 jeeds had the motor moved two inches further foward to compensate for this, you could go that route but i found it easier to lenghten the fron drive shaft.
Re: ax15
« Reply #5 on: October 26, 2010, 11:35:37 PM »
the dakota bellhousing i got was about 1'' deeper, that's why I ended up with the longer pushrod.
sbsg2005
Re: ax15
« Reply #6 on: October 26, 2010, 11:44:45 PM »
Mine was to, but i guess i just got lucky. In my last post i forgot to mention that i got my t-case input from a durango i found a case at the local pull apart some one had already tried to take apart but failed to get apart and took it out of there. I wish all t-cases were as easy to get apart and the 231 i had it swapped out in less that a half hour. By the way the reason you need to swap the input is the ax-5 has a 21 spline input and the ax-15 has a 23 spline input.
N8whitie
Re: ax15
« Reply #7 on: October 27, 2010, 09:23:54 AM »
Wow, thanks guy. Sounds like a really involved project. Don't get me wrong, I love involved projects but with all the parts you have to swap out it seems that alot can go wrong down the road. Anybody have any problems? Jeffy also suggested an NV3550... which seem harder to find, will these bolt in easier? I've looked around and believe it or not these topics are pretty far and few between on forums or write-ups.
sbsg2005
Re: ax15
« Reply #8 on: October 27, 2010, 11:12:39 AM »
the hardest part is finding the bell and swapping the input the rest is just like when you replace the clutch the nv3550 will require the same parts if i remember right so it would be just as involved. plus the 3550 cost a heck of alot more when you find one.
Re: ax15
« Reply #9 on: October 27, 2010, 11:55:57 AM »
the pilot bearing is different i think on the 3550 (or i could be wrong) - that's what i got and i used an Advance Adapters pilot bearing for (I'm not sure) a 4500 transmission - if that's what you used also it means they're the same. the rear output shaft on the 3550 has it's own seal, i believe the ax15 seals on the input of the t-case just like the ax-5 (but again this is from what i remember when i looked for parts for this swap).
I have some pictures and a little writeup on the swap in the Member's projects in my drivetrain upgrades thread if you want to have a look.
sbsg2005
Re: ax15
« Reply #10 on: October 27, 2010, 12:49:39 PM »
i will look as my ax-15 is on its last legs and i have been think about a 3550.
Re: ax15
« Reply #11 on: October 27, 2010, 10:50:26 PM »
some of the very late YJ's and Then the TJ's had the 23 spline shaft behind the Ax5 / 2.5 combo...
Re: ax15
« Reply #12 on: October 28, 2010, 07:42:23 AM »
I sure hope my '95 YJ (TJ fan belt, TJ rear hinges, TJ hood/window bumpers) is like that!
Re: ax15
« Reply #13 on: October 28, 2010, 07:46:01 AM »
Mine was made in june 94; I wonder how many splines i has...  Would defenetly be interesting to put a AX15 in there.
Re: ax15
« Reply #14 on: October 28, 2010, 08:52:29 AM »
no chance
