Author Topic: ax15  (Read 5672 times)
Re: ax15
« Reply #15 on: October 28, 2010, 11:57:03 AM »
some of the very late YJ's and Then the TJ's had the 23 spline shaft behind the Ax5 / 2.5 combo...
Where have you seen this?  Every TJ AX5 I've seen is 21spline.  Even my '95 YJ was 21spline, and it's part TJ, even the 231 internals are a crossbreed between YJ and TJ.
Re: ax15
« Reply #16 on: October 28, 2010, 12:41:26 PM »
never heard of 23 spline AX-5 either, i think the late TJs had the same t-case between 4 and 6 cyl but they didn't have the AX5 anymore.
Re: ax15
« Reply #17 on: October 28, 2010, 12:42:55 PM »
Mine was made in june 94; I wonder how many splines i has...  Would defenetly be interesting to put a AX15 in there.
A '94 could have been made as early as '93.  A 95.5 could be made as late as '96.
Re: ax15
« Reply #18 on: October 29, 2010, 12:25:27 AM »
My 94 has it. Thats why I brought it up. I was told by a dealer mechanic that Chrysler ran out of AX5 transmissions
in 94 and the later orders had the 23,, what can I say mine is the Bast*** version in more ways than that...
I know that they had a lot of trouble replacing my transmission when it blew up under warranty, took them 2 weeks to get
the parts.
Re: ax15
« Reply #19 on: October 29, 2010, 02:47:26 AM »
First I've ever heard of one, and I rebuild a LOT of 231's.
sbsg2005
Re: ax15
« Reply #20 on: October 29, 2010, 09:16:11 PM »
i looked for a 23 spline out put for a ax-5 just now and couldnt even find a part number
Re: ax15
« Reply #21 on: October 30, 2010, 11:17:03 AM »
I believe it was a toyota or Mazda part but since mine is working (knock on wood) I'm not going to worry too much right now..... LOL
Offline lax22
Re: ax15
« Reply #22 on: November 03, 2010, 01:40:25 PM »
How hard is it to find an AX15 throwout bearing for this swap? From what i've heard its different from the AX5 and NV3550 one.
Re: ax15
« Reply #23 on: November 03, 2010, 01:44:06 PM »
I'm pretty sure they are the same (that's what i remember) but I'll check and report back shortly
EDIT:
same P/N all the way to 2006 (for the 4.0L) as the one for the AX5
Timken Part # 614093  Ball Bearing; Bore=1.435", Outer Diameter=3", Width=2.008"
this is for external slave AX5
« Last Edit: November 03, 2010, 01:52:46 PM by sharpxmen »
sbsg2005
Re: ax15
« Reply #24 on: November 04, 2010, 09:09:13 PM »
it is the same throw out bearing
