Author Topic: Washed engine compartment...now I got problems  (Read 2530 times)
oldskool71
« on: October 26, 2010, 02:27:16 AM »
drove it right after I washed it...no problems...a couple hours later...started it up....rpm's went right up to 2g's...and check engine light came on...idle goes up and down...spudders between 2-3'gs when driving...feels like loss of power...disconnected the battery overnite...next morning hooked it up...no check engine light...seem to run fine...drove it a little no problem...a few hours later...started it...idle went up...check engine light came back on...and we are going through the same motions once again....any clues???
« Last Edit: October 26, 2010, 02:28:38 AM by oldskool71 »
Re: Washed engine compartment...now I got problems
« Reply #1 on: October 26, 2010, 12:49:47 PM »
Vacuum leak would be my first guess.
« Reply #2 on: October 26, 2010, 05:15:47 PM »
cel code?
oldskool71
« Reply #3 on: October 27, 2010, 11:01:44 AM »
I believe is was P0122 and P0123...if I remember correctly....something to do with the TPS low and high voltage?
« Reply #4 on: October 27, 2010, 11:58:47 AM »
then it should be the tps, do you have a spare? easy to swap for a test and by the way you describe it makes sense as far as behavior goes.
92wrangler
« Reply #5 on: October 27, 2010, 01:34:21 PM »
I would check the connector to the TPS. It may have gotten water in it and is now shorting or corroding. I had a Neon where a lot of troubles came from green conductors inside the connectors. Use a blow-dryer if it looks wet inside.
« Reply #6 on: October 27, 2010, 02:08:58 PM »
Clean up the TPS and reconnected.  If that does not work, replace it (it's VERY easy, and IIRC, not that expensive).
« Reply #7 on: October 27, 2010, 02:21:20 PM »
unless it was hacked those connectors are weather tight so they should not let water in (well, unless the jet was right on it) - doesn't hurt to try though, some dielectric grease would also keep it from corroding in the future.
oldskool71
« Reply #8 on: October 27, 2010, 03:04:29 PM »
thanks for all the replies...I ordered a factory replacement...hope to have it soon...I will let you know the outcome...Ron
knotts89
« Reply #9 on: October 28, 2010, 12:12:34 PM »
i did the same thing and had the same problem but mine cleared up by itself after running it a bit. turned out a little bit of water had gotten on the number 3 plug or wire. started doing fine after it dried up and have had no problem since
« Reply #10 on: November 02, 2010, 01:46:01 PM »
Keep the old sensor and let it dry out for a few days then see if it works.  If it does then keep it as a spare.  Typically, water is not a problem unless you're using a pressure washer.  Although, some hoses do have narrow nozzles.  If you're worried then take some plastic bags and over areas where you have to spray close to electronics.
« Reply #11 on: November 02, 2010, 02:42:23 PM »
I ussually get a CEL when  clean my engine; last time, it was the 02 sensor voltages acting up, but they cleared themselves up...
oldskool71
« Reply #12 on: November 07, 2010, 12:20:37 AM »
just wanted to update you all...got the new OEM TPS....swapped it out....and the thing runs better than it did when I bought it...must have been on the way out...thanks for the help...im glad there is a place just for us 4bangers... :doggy:
 :wall:
