Author Topic: Regearing!!!  (Read 3667 times)
sailorjerry13
Regearing!!!
« on: February 22, 2011, 09:40:59 PM »
Hi everyone, i have a '95 yj w/ 2.5 and just threw some 31's on it, today i went to my local shop and they said they recommend 4.56 ratio, is this to low? Is this to high? What do you guys think?
Re: Regearing!!!
« Reply #1 on: February 22, 2011, 09:48:49 PM »
4.56 brings it back to "like" stock rpm to speed ratio, most people here would tell you to go 4.88 so i wouldn't say it's too low at all.
Re: Regearing!!!
« Reply #2 on: February 23, 2011, 05:54:58 AM »
+1 on 4.88's
DodgeMudder
Re: Regearing!!!
« Reply #3 on: February 23, 2011, 09:48:15 AM »
I wouldn't change gears for 31's not enough difference from stock to justify the cost, if you need to change gears then go 4.88s you will notice a bigger difference and be set to go up to 33's
Re: Regearing!!!
« Reply #4 on: February 23, 2011, 10:34:04 AM »
 :thumb:
4BangerTJ
Re: Regearing!!!
« Reply #5 on: February 23, 2011, 12:12:37 PM »
I personally wouldn't change gears for 31s. I currently have 31s on mine after coming with 205s stocks and its fine. Still does 70 fine still plenty peppy. I will be going to 4.88s when I put on 35s next month but that's a must have with that big of tire but IMO a waste of time and money for 31s.
Re: Regearing!!!
« Reply #6 on: February 23, 2011, 12:28:58 PM »
I got 4.88's for my 33's and love it.. would even go bigger if my diff's would have allowed it.  building jeeps is very addictive so if you already got 31's on it you probably will end up going bigger tires later.. the only thing 4.88's will hurt you is in mpg's you will love it with your 31's for power and accelerate.. I had put 215's "28's" on mine while I was doing some body work and it was a hot rod it was so quick and wasn't that bad on the highway..
it's never a waste to re-gear to 4.88's not in a underpowered jeep. if you were rocking a 6cld or v8 I would change my opinion a bit if you were doing highway a lot..
sailorjerry13
Re: Regearing!!!
« Reply #7 on: February 23, 2011, 08:15:43 PM »
Thanks for the answers guys, the gentleman at the shop said that with the 4.56 i could still go to 32's or 33's
Re: Regearing!!!
« Reply #8 on: February 23, 2011, 08:21:35 PM »
I would go 4.88's trust us
Re: Regearing!!!
« Reply #9 on: February 23, 2011, 08:22:47 PM »
Your stock gears are either 4.10 (manual) or 3.73 (auto), so switching to 4.56 isn't much of a change, not worth the expense and trouble.  Go 4.88 and don't look back, especially if you think you will ever go larger (we all do LOL).
sailorjerry13
Re: Regearing!!!
« Reply #10 on: February 23, 2011, 08:24:18 PM »
Would the 4.88 still work well even if i decide to keep the 31's?
sailorjerry13
Re: Regearing!!!
« Reply #11 on: February 23, 2011, 08:36:49 PM »
My yj is stick by the way, the thing is that i feel like the engine is bogging, i cant use the 5th gear or go over 60mph, gas milage is poor and it feels heavy as hell
Re: Regearing!!!
« Reply #12 on: February 23, 2011, 08:47:44 PM »
yes even with 31's you will end up bigger I'm sure of it anyway but they will still work good with 31's
sailorjerry13
Re: Regearing!!!
« Reply #13 on: February 23, 2011, 08:59:52 PM »
Awsome, i'll take your word for it since u have the experience, thank you guys so much for the info
Re: Regearing!!!
« Reply #14 on: February 24, 2011, 06:30:06 AM »
31" and 4.88 will be just fine.
