Author Topic: Would a 4.0 liter cold air intake fit on a 2.5 liter ?  (Read 4066 times)
karan
« on: May 09, 2011, 04:32:45 PM »
Family, hope every body is doing just great.
I got a quick question, would this air intake fit on my 2000 jeep tj 2.5
http://www.autoanything.com/air-intakes/61A1817A0A0.aspx
plus if you got a suggestion for a better intake system, plz dont hesitate to further my knowledge.
Re: Would a 4.0 liter cold air intake fit on a 2.5 liter ?
« Reply #1 on: May 09, 2011, 05:00:26 PM »
I don't think you can without modifications.  The TB locations is slightly different, IIRC.
« Reply #2 on: May 09, 2011, 05:08:31 PM »
you can probably make it work, however like he^ said the position of the t/b on the 4.0 is closer to the rad/grill, so a longer coupler or some fiddling with the pipe routing might be necessary
what would be interesting is what actual system are you getting, from the link you poster there is a picture with just a pipe and a filter and i think that is ridiculous at $212, but if you click on one of the thumbnails there is a Rubi with a really nice airbox, which would actually be more reasonable at that price.
- actually i just looked again and the ones with an airbox are $287 amd $328 (probably based on the type of filter), forget it - not worth paying $212 for a plastic pipe with a filter at the end (so no screen and therefore not really cold air but hot air from under the hood).
karan
« Reply #3 on: May 10, 2011, 09:48:28 PM »
Thanks a lot Guys, i will probably drop the idea then, would rather spend my hard earned $ in electric fan conversion.
Peace.
« Reply #4 on: May 10, 2011, 10:59:46 PM »
Apollo K&N is better and cheaper if you want to go that route at some point.
also for a little bit more you can go with a snorkel (that is true cold air) and a fram airhog or K&N filter in the stock airbox.
karan
« Reply #5 on: May 13, 2011, 10:05:44 PM »
I will try k&n in the stock airbox first, tx sharp!
« Reply #6 on: May 13, 2011, 11:30:36 PM »
Depending on where you live you might want to stick with the paper.  Performance-wise, the paper isn't going to make more HP but filtering-wise, it's usually better then the K&N.  Although if you don't live where there is fine dust particles then it shouldn't be a problem.  Most of the guy's I know who run in the semi-arid plains have either stopped using K&N's or use a pre-filter.
« Reply #7 on: May 14, 2011, 12:44:57 AM »
he's on the other side of the border in Alberta (opposite to the south) :guns: :wall: :lol:
« Last Edit: May 14, 2011, 12:46:13 AM by sharpxmen »
karan
« Reply #8 on: May 15, 2011, 06:23:05 PM »
haha, the smileys are too funny Sharp, yeah Jeffy i get your point with the dirt and k&n not being best friends, thanks for the info.
And as Sharp said m from Calgary and dirt isnt a big of a problem here, so i figure it should be fine to use k&n
but just to be on the safe side m am goin to get k&n oil filter as well that is better in keeping dirt particles out of engine than regular oil filters (i just read about it, dont know if thats true)
« Reply #9 on: May 15, 2011, 07:32:38 PM »
My Fram Airhog has done a pretty good job holding the dirt out so far...  Even in the dusty conditions we drive in!
This is the type of dust I am talking about:
<a href="http://www.youtube.com/v/UxbFuS4bktw?hl=en&amp;fs=1" target="_blank" rel="noopener noreferrer" class="bbc_link bbc_flash_disabled new_win">http://www.youtube.com/v/UxbFuS4bktw?hl=en&amp;fs=1</a>
And here is how my airbox looked after such trips:
Lower half:
Upper Half:
No prefilter on the snorkel (although it's probably a good idea!)...
