Author Topic: B&M or Hurst shifters for AX-15 work on AX-5?  (Read 4825 times)
  • 4BangerJP.comŪ Donator
« on: May 24, 2011, 07:59:01 AM »
Have been looking around for some clues on this.  Looks like B&M maybe used to make an AX-5 version and I think I saw something by Hurst on Ebay that was advertised for the 4Banger.   Do the models by B&M and Hurst for the AX15 work on the AX5 maybe?
Re: B&M or Hurst shifters for AX-15 work on AX-5?
« Reply #1 on: May 24, 2011, 08:08:45 AM »
According to some advance adapters instructions, the AX-5 shifter can be adapted to the AX-15 but the bolt holes have to be modified.  So it won't be bolt on but don't know if it can be made to work.
« Reply #2 on: May 24, 2011, 08:12:08 AM »
why are you looking to do this mod? just wondering...
« Reply #3 on: May 24, 2011, 09:09:43 AM »
I've thought about adding a Hurst.  Hurst no longer makes a AX-5 shifter.  You will have to modify a AX-15 to work.  It's not hard unless you don't have the tools.  The base plate needs to be disassembled and turned around.  Then two of the holes need to be elongated.
B&M makes a AX5 shifter which is a little cheaper then the Hurst but I like teh Hurst more.
« Reply #4 on: May 24, 2011, 04:40:00 PM »
The usual reasons, particularly shorter shift throw.  Don't "have" to have it -- nothing wrong with my shifter now.
« Reply #5 on: May 24, 2011, 04:44:47 PM »
that's why I was asking, usually you do the short shift throw so you decrease the shift times, hard to assume that's what our Jeeps are missing :lol:
don't get me wrong, if money are not an issue then yeah, it's nice to have, but i think you could spend it on something more useful.
« Reply #6 on: May 24, 2011, 05:11:49 PM »
Shorter shifts are nice especially if you spend a lot of time on the road.
« Reply #7 on: May 24, 2011, 06:49:11 PM »
I would consider one for a body lift. would help if you had to extension the sifter making it closer to stock throw again.
  • Servicing Squirrels Since 1995Ū
« Reply #8 on: May 24, 2011, 10:48:45 PM »
I thought a bit of time between gears is easier on the synco's?  :confused:
« Reply #9 on: May 24, 2011, 11:42:24 PM »
Only if you're lazy and don't know where your shift points are.
