Author Topic: fuel filter swap  (Read 37572 times)
Re: fuel filter swap
« Reply #75 on: July 03, 2011, 03:56:21 PM »
He has no oil pressure at Idle. But did say when he reved it it came up to 40 then went back down.  Me I would put on a mechanical gauge and make sure.
  Also just thought of this is there not a problem with mixing YJ and XJ gauges and sending units.  Think I read about this on another place while searching the web.
« Last Edit: July 03, 2011, 03:57:08 PM by grumpygy »
bammerman
« Reply #76 on: July 03, 2011, 05:37:53 PM »
I think I have the sending unit off of the 88 but I do still have the YJ gauges.  I know I have some pressure because by mistake we started it without the filter on (someone moved a tad bit to fast) and it blew out all the oil.  I would think if there was no pressure none would have come out.  I am going to find someone with a tester so we can manually test it, and do a compression test as well.
« Reply #77 on: July 03, 2011, 06:15:50 PM »
Does the XJ have an oil light and not a gauge?
bammerman
« Reply #78 on: July 03, 2011, 06:24:58 PM »
Well the gauges I got from it were aftermarket I believe. I went to try to hook it up to the YJ ones and there were no wires.  need to look into my electrical book and see if it is possible.
bammerman
« Reply #79 on: July 05, 2011, 08:28:29 AM »
Not sure if.this is normal but my head gasket looks to be made out of cork and is almost a 1/4 thick. All the ones I have seen are not cork. Is this a normal practice?
« Reply #80 on: July 05, 2011, 10:05:58 AM »
cyl head gasket? ???
they are not made out of cork, post some pictures
they are not 1/4'' thick either so that's a red flag regardless.
who rebuilt the engine?
« Last Edit: July 05, 2011, 10:07:35 AM by sharpxmen »
bammerman
« Reply #81 on: July 05, 2011, 11:33:21 AM »
I will take some pictures when I get off of work.
« Reply #82 on: July 05, 2011, 12:29:27 PM »
Valve covers or heads?  How are you able to see the gasket for the heads?
« Reply #83 on: July 05, 2011, 01:01:09 PM »
i'm assuming he removed the head, it did cross my mind that would be the valve cover gasket but then i thought the head gasket is pretty specific
bammerman
« Reply #84 on: July 05, 2011, 02:14:09 PM »
This is the location that I can see cork, I think. Going to take an exact picture when I get home.
« Reply #85 on: July 05, 2011, 03:12:50 PM »
here's a thought: what oil pressure sender do you have on that motor? did you put your's in there or it's the one that came with it - they are different between certain years
bammerman
« Reply #86 on: July 05, 2011, 03:39:31 PM »
I do not remember that was almost a year ago.  I can take a picture if that will help too. I am leaving to go home now
« Reply #87 on: July 05, 2011, 04:22:54 PM »
i'd say just put a mechanical gauge on it that will give you the answer right away, my guess is that is the wrong sender (doesn't make sense to go 40psi revved and 0 at idle, would be really noisy in that case).
bammerman
« Reply #88 on: July 05, 2011, 05:35:40 PM »
My new mechanic is coming over tomorrow or next day to pressure test it.  Here is the gasket I was talking about - shit looks like wood.
« Reply #89 on: July 05, 2011, 11:02:40 PM »
I'm going to guess it's a reinforced composite and not cork.  If you really don't trust the work done to the engine, pull it apart and assemble it yourself.
