Author Topic: Turbochargers  (Read 200355 times)
st.chevrolet
Re: Turbochargers
« Reply #315 on: April 11, 2010, 10:03:18 PM »
I orderded the cooling mist kit, they ask, "Tell us your horsepower or receive the standard 380 CC injector." What injector are you running?
My injector would be close to their 90cc injector.
« Last Edit: April 11, 2010, 10:29:01 PM by st.chevrolet »
enginethatcould
Re: Turbochargers
« Reply #316 on: April 12, 2010, 08:25:35 PM »
I think I'm getting close to starting my turbo build. I have been gathering parts for close to a month and should be pretty close to jumping off. Here is my list so far, if I have missed something please let me know.
1) airesearch T3 from '81 benz
2) manuel boost controller
3) blow off valve
4) methanol / water injection
5) boost gauge
6) oil supply and return lines
7) psc1-002
Items that I plan to get or I'm working on:
1) AFR
2) injectors
3) piping
4) heat wrap
5) turbo mount
st.chevrolet
Re: Turbochargers
« Reply #317 on: April 12, 2010, 10:21:10 PM »
3) blow off valve
5) boost gauge
7) psc1-002
1) AFR
2) injectors
3) piping
4) heat wrap
5) turbo mount
Did you get the PM I sent you regarding the water/meth injector?
You can add - adjustable fuel pressure regulator (talk to Sharpxmen)
Air filter,colder plugs
Re: Turbochargers
« Reply #318 on: April 12, 2010, 10:38:28 PM »
he did, got a couple in the works, should have it shipped out to him this week
x2
plugs 2 levels colder
enginethatcould
Re: Turbochargers
« Reply #319 on: April 13, 2010, 11:38:43 AM »
I did get your message and had them send me the 90cc injector. So other than a few minor things I should be about ready to go. What size pipe are you running on the iduction side?
x2
Thank you both for all the knowledge you have shared with me thus far!
Re: Turbochargers
« Reply #320 on: April 13, 2010, 12:15:58 PM »
i am using 3'' to the filter and 2.5'' after that (although i want to upgrade to a larger ID from the filter to the t/b since my t/b is 64mm and the 2.5'' pipe is a hair below 60)
In your case i would at a minimum match whatever your turbo inlet is (at the tip, not at he turbine). You should be good with 2.5'' and at the most 3'', anything over  would result in negligible gains for the CFM you would pull with 6psi of boost (or even 8) for the size of the motor.
st.chevrolet
Re: Turbochargers
« Reply #321 on: April 13, 2010, 03:48:14 PM »
On the filter side I matched the pipe to the turbo inlet size and then had the pipe expanded to match a K&N I already had. For the turbo outlet pipe I matched the pipe to the TB size ( I have the 4.0 TB) and used a silicone reducer right at the turbo to step it down to the turbo outlet size. You can see the pics in my thread.
enginethatcould
Re: Turbochargers
« Reply #322 on: April 13, 2010, 09:48:03 PM »
This may seem like a stupid question but, how do I go about getting a colder spark plug?
Re: Turbochargers
« Reply #323 on: April 13, 2010, 10:24:19 PM »
I bought NGK ZFR7F which have the same specs as the stock ones other than being 2 numbers colder, stock ones are 5 these are 7, they go backwards - the lower the number the hotter the plug - the colder the plug the faster it removes heat from the chamber.
$2.50 each on ebay + about $4 for shipping
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=380084512032&viewitem=&sspagename=STRK%3AMEWNX%3AIT
buckmaster
Re: Turbochargers
« Reply #324 on: April 19, 2010, 07:18:41 PM »
Ok I am new to this site and have spent the last 2 days searching about turbo's and I want to know what you guys think about this turbo kit http://cgi.ebay.com/ebaymotors/Jeep-TJ-T3T4-Turbo-Charger-Kit-_W0QQcmdZViewItemQQhashZitem3efb5a0355QQitemZ270504952661QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Sorry if this has been covered before but I couldn't find it.  It seems like a pretty complete kit to me.  Thanks for the help
Re: Turbochargers
« Reply #325 on: April 19, 2010, 08:03:34 PM »
far from complete and probably with parts that you don't need or never use - not sure why they call it TJ kit as there is nothing in there for TJ - just a bunch of parts (made in China most likely) that a street tuner would use put together in one package.
Re: Turbochargers
« Reply #326 on: April 19, 2010, 09:32:25 PM »
I've helped build several turbo cars. If you want success, lack of issues, and a decent running engine, start with a name brand stand alone engine management kit, then the turbo....
st.chevrolet
Re: Turbochargers
« Reply #327 on: April 20, 2010, 10:28:18 AM »
X2
Re: Turbochargers
« Reply #328 on: April 20, 2010, 12:11:47 PM »
i think MSD has some standalone MPFI systems (ECU and harness only) that work for 4/6/8 cylinders and they range from $1,200 to about $1,600 - not sure how well they work and if you can use the stock sensors (like crank, cam, tps, IAT, CTS - map will work but for forced induction you'll need one that matches the boost most likely 2bar in this case).
and there's always Megasquirt and the piggybacks for a cheaper alternative.
chrisjsmith4
Re: Turbochargers
« Reply #329 on: April 20, 2010, 09:45:15 PM »
Ok. Jeep is at the dyno shop and is getting tuned tomorrow. I'm so excited. I'll get you guys some numbers on what its running. For those of you who missed it, i'm having the ftc1 installed to be able to tune the motor. I'll take some pics and stuff for you guys too.
