Author Topic: Still leaks...  (Read 29165 times)
Re: Still leaks...
« Reply #75 on: April 21, 2010, 05:17:17 PM »
In all honesty, what I did with mine was use silicone on the outer windshield lip and seal it that way.  I just got too tired of water coming in...
I've done that as well with my original.  When it came to replacing it it was a bit of a PITA with the silicone.  It's kind of a dumb design to have the big flange area sticking out and catching water.  Might end up having to apply a little RTV to the backside though.
Re: Still leaks...
« Reply #76 on: April 21, 2010, 05:29:33 PM »
i did the same thing but it turns out it leaks from somewhere else.
I still can't see where it's leaking from but there was a wet spot on the drivers footwell again.  I'm going to reattach the upper windshield brackets so all of the stress isn't on the bottom bolts when it gets sunny again.  I think the other leak stopped though.  It was dripping down the face of the speaker before.
i get the same thing, by the driver's feet - didn't get around to cover the vent to see if that's where the issue is.
Re: Still leaks...
« Reply #77 on: April 21, 2010, 05:42:27 PM »
I noticed on mine that when it rained sideways, I did get some water on my feel.  Turned out that the little dent that I made when I routed the Daylighter's cables was enough to let water in.  The water would go all the way to the wiper wires hole, and drip on my feet.  A little silicone on the edge and around the aforementioned hole, and I have not had leaks since (of course, I also keep the Jeep in a garage now, which helps, as the side rain was only an issue when parked, not when driving).
Re: Still leaks...
« Reply #78 on: November 28, 2011, 08:36:52 AM »
Jeffy,
when you replaced the seal, did you reuse the plastic buttons (if i remember correctly that's how it is secured to the windshield frame) or did you buy new ones? if the latter what did you get and where did you buy them from? thanks in advance.
Re: Still leaks...
« Reply #79 on: November 28, 2011, 12:37:39 PM »
Jeffy,
Plastic buttons?  For the cowl seal, there are 6 screws that attach it to the bottom of the windshield.
Re: Still leaks...
« Reply #80 on: November 28, 2011, 07:01:59 PM »
ok, that's better - for some reason (just the picture i had in mind) i thought they are those plastic plugs like the ones that hold the rubber screens on the inner fenders (it's been quite a while since i lowered the windshield).
Re: Still leaks...
« Reply #81 on: December 01, 2011, 05:01:37 PM »
ow look what you did start talking about this leak and now my drivers side is leaking..  Not to worried about it for now as I just have sound deadener on the floor and no carpet.  The drain holes are open so as soon as I move it they will drain.  Its parked on a hill right now.
Supposed to have bad fog in the Morning so was checking the jeep out to take to work.  Fog lights on my truck are not that good.  Just put new lights on the jeep and it should be no problem.  Put on a cheap set of fog lights, then put in a set of Hid Bulbs into them.  Sure does light up the area.
