Author Topic: Transmission for my 97 TJ 4 banger  (Read 2742 times)
Contra
« on: July 01, 2010, 08:59:21 PM »
new here, and glade I found this place
I would like to get a new trans for my 97 TJ, currently I have a 3 speed auto and would love to get a 4 speed auto from a I6
would I have to use a different transfer case or would mine bolt up
or would I have to use an adapter such as I will have to use for the engine to bolt up to the trans?
Re: Transmission for my 97 TJ 4 banger
« Reply #1 on: July 01, 2010, 09:52:42 PM »
A 4-speed won't bolt up.  2.5L's and 4.0L's use different bell housing bolt patterns.  The 4-speed found in later TJ's was because they went from the 2.5L to the 2.4L which shares the 4.0L bell housing bolt pattern.
« Last Edit: July 01, 2010, 09:52:56 PM by Jeffy »
Contra
« Reply #2 on: July 04, 2010, 02:12:45 AM »
so is it worth getting my trans rebuilt or can I use a different trans (with the help of an adapter plate)
« Reply #3 on: July 04, 2010, 10:27:01 AM »
Is there something wrong with yours, or are you looking for an auto with overdrive?
Contra
« Reply #4 on: July 04, 2010, 12:56:02 PM »
it is starting to slip, (I think it is a sensor)
so I dont really wanna repair it i would rather not put money into it as I wont be happy with it anyway
I really want to get a stronger built trans as I kinda make it work harder than most drivers do
and over drive would be a plus, so a higher highway speed with less RPM would be great!
« Reply #5 on: July 07, 2010, 05:50:20 AM »
I think they're pretty rare but a Cherokee with a 4cyl and auto should be the sweet AW4 transmission, a 4spd auto with an OD gear.  Google 'AW4 swap" and you will get some good info.
« Reply #6 on: July 07, 2010, 12:25:51 PM »
Mid-90s Dakotas ran the 2.5l engine. Many in front of a AX-15 so that is a typical swap for swapping manuals trans. I would think an auto from the same typical truck would also work in the Jeep. Just make sure you get the 4wd model. The output should be the same as your Jeep auto with 23-spline. Only issue I can see that may come up is the depthness of the shaft. Meaning the length of the trans output and the length of the tcase input.
« Reply #7 on: July 08, 2010, 12:50:33 AM »
The 4spd auto is longer than the 3 spd the one from the XJ won't fit unless you
move the motor forward or are happy with a 2" driveline in the rear...
« Reply #8 on: July 08, 2010, 03:34:45 AM »
The AW4 is becoming quite popular in Wranglers, both in the 4cyl and 6cyl, with sufficient length rear driveshafts.
Contra
« Reply #9 on: July 08, 2010, 07:43:15 AM »
thanks for all the advice guys
bu I am going to the dark side (in a big way)
I have a 5.2 and trans and thay and the axles are gonna go under my jeep frame soon (just gotta buy an arc welder)
so problem solved...thanks anyway
I guess I gottta leave the club when this happens
« Reply #10 on: July 08, 2010, 08:39:49 AM »
we'll just think of you as having 2 4bangers under the hood
Contra
« Reply #11 on: July 08, 2010, 08:03:02 PM »
lol...8 ticked-off racoons
« Reply #12 on: July 08, 2010, 11:47:42 PM »
Rabid Squirrels? :biggrin:
