Author Topic: Bucket of bolts art  (Read 87432 times)
Re: Bucket of bolts art
« Reply #225 on: June 21, 2012, 10:16:12 AM »
This Les Paul was commissioned.
The 4 screws that act as knobs spin.  :naughty:
It's about 13 inches long.
« Last Edit: June 21, 2012, 04:52:26 PM by FourbangerYJ »
« Reply #226 on: June 21, 2012, 10:22:56 AM »
that's nice man
« Reply #227 on: June 21, 2012, 10:25:22 AM »
« Reply #228 on: June 21, 2012, 04:29:07 PM »
What's the outer band made from?
Would have been cool if it was playable.  Real tuners and such.
« Reply #229 on: June 21, 2012, 04:49:56 PM »
1/2inch wide 1/8 thick steel. That outline is made from 4 sections. I scored it with the grinder to get it to bend in the shape.
« Reply #230 on: June 21, 2012, 04:51:30 PM »
Here is just the outline.
« Reply #231 on: June 21, 2012, 10:16:07 PM »
Was that an Epiphone you're copying?  The head stock should of had an open book look to it and not clipped corners if it was an Epiphone.
« Last Edit: June 22, 2012, 02:58:58 PM by Jeffy »
« Reply #232 on: June 22, 2012, 09:45:44 AM »
Was that an Epiphone you're copying?  The head stock should of had an open book look to it and not clipped corners if it was a Gibson.
Not knowing squat about these I was looking at photo's from a search. They showed both styles. I wasn't sure which was correct or if both were correct. So I picked one.
« Reply #233 on: June 22, 2012, 03:02:24 PM »
Yeah, there's a difference, in some circles a big one.  Epiphone Les Pauls are usually the value line while Gibson is the premium.  That's the only difference you'd notice with the art piece since all of the other differences are wood finish and hardware related.
« Reply #234 on: August 01, 2012, 09:08:04 PM »
Ok how's this one?
« Reply #235 on: August 02, 2012, 03:14:31 PM »
Better headstock.  Can you strum the string or is that wire too thick?  I think adding tuner pegs (even fake ones) and having real guitar strings would allow you to have more viewer involvement.  I'm sure looking at it people would wants to strum those strings.  Maybe run bolts up through the headstock with holes drilled through them.  You could then lock them in place with a nut which would allow you to tune the strings a little.  You would need a way to get to the other side of the strings on the body side though.  Also, I'd maybe consider something to simulate humbuckers pickups.  Not that it needs to be heavier.
« Reply #236 on: August 02, 2012, 04:15:31 PM »
The strings are 28ga and 34 ga wire. They can be strumed but it sounds bad. It's hard to get the wire tight by hand. The steel ruler is much to thin to try and weld a nut to make the proper tuner pegs. This is more of a show piece than a user.
It's hard to fit stuff in there. I would love to come up with something to resemble the pick ups but fitting stuff in to fill up the space gets tricky and the surface is not even. I have less than a 1/2 inch thickness to work with. I had to cut about a 1/8 off the cam lobe. Trying to add the pick ups would be tough.
It's heavier than you think. When you pick it up most people are surprised. I am not worried about weight. It is what it is.
« Reply #237 on: August 02, 2012, 07:30:35 PM »
No, I'm pretty sure it's heavy as is.
« Reply #238 on: August 03, 2012, 08:44:02 AM »
It looks great!  Your art just keeps getting better and better.
« Reply #239 on: September 20, 2012, 08:41:59 PM »
I made this for my wife's aunt.
